Help with AMD EXPO
4 minutes ago, Sev717 said:I'm a first time PC builder who has recently just built his first PC, and while looking up what to do after I finished, I found everyone recommending me to turn on XMP. I did a little more research, and I found that EXPO is better than XMP for amd cpus, so I opted to turn that on rather than XMP. However, once I turned it on and rebooted, my motherboard showed a solid orange light. Eventually, it did start up with EXPO enabled, but frankly, the orange light stresses me out, and it comes back every time i shut down and start up my PC again. It also takes a good 3-5 minutes to boot up every time.
Is this expected, normal? If not, what could the issue be and how do I fix it? I currently have it turned off because I'd prefer to avoid the mini heart attack I get every time I start up my PC. PC gurus help
MoBo: MAG tomahawk b650 wifi
CPU: amd ryzen 7 7700x
Ram: corsair vengeance ddr5 32gb rgb cl30 6000mhz
(I don't know if these are all the relevant parts, if there's anything else just let me know.)
EXPO is just AMD's name for the same thing XMP does.
Memory training can happen in the beginning (and randomly it seems), but 3-5 minutes is a long time. There is a Memory Context setting in the BIOS you can check to help, but the most up to date BIOS speeds things up too.
