title^^
windows 7 64bit home premium sp1, recently fresh installed on sdd
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/15741-recycling-bin-wont-empty-c/
Simple, delete the recycling bin.
https://linustechtips.com/topic/15741-recycling-bin-wont-empty-c/#findComment-177281
What does it say when you try and empty the recycle bin?
"Are you sure you want to permanetly delete all of these items" then i click yes and it doesn't do it
https://linustechtips.com/topic/15741-recycling-bin-wont-empty-c/#findComment-177309
Your Recyle Bin maybe corrupted I guess.
Try deleting the recycler folder(s), Windows will recreate it when you reboot. From a
command prompt issue the following command:
rd /s /q c:\recycler
If you have more than one drive you will have to issue the command for
each drive, changing the c: with the appropriate drive letter. If you
have more than one user on the machine all recycle bins will be emptied.
Join the LinusTechTips Star Citizen Org :D ~ https://robertsspaceindustries.com/orgs/UOLTT
https://linustechtips.com/topic/15741-recycling-bin-wont-empty-c/#findComment-177317
I did that and it said "The system cannot find the file specified." >.<
https://linustechtips.com/topic/15741-recycling-bin-wont-empty-c/#findComment-177338
did you mean this?rd /s /q c:\$Recycle.Bin
https://linustechtips.com/topic/15741-recycling-bin-wont-empty-c/#findComment-177347
i did "rd /s /q c:\$Recycle.Bin" and it didn't work :/
https://linustechtips.com/topic/15741-recycling-bin-wont-empty-c/#findComment-177366
Right click the recycle bin and set the allocated amount on your drive to none it should remove all the files stored there.
https://linustechtips.com/topic/15741-recycling-bin-wont-empty-c/#findComment-177485
didn't work, it changed it to 1 (i put 0) but it still didn't delete anything. i checked dont move anything to recycling bin, remove immediately when delete which still didn't do anything :/
https://linustechtips.com/topic/15741-recycling-bin-wont-empty-c/#findComment-177517
i had this once, but i forgot what method i used
i think i used method 3 in this but you said it didnt work, make sure you are running it as admin. maybe try 1 and 2
Method 1:
Right click recycle bin > properties
Uncheck "Display delete confirmation dialog"
Method 2: Try to empty recycle bin using the disk cleanup tool.
Disk Cleanup - Click start / Double Click Computer / Right Click on the C: and select Properties / General tab / Click disk cleanup,in Disk cleanup select recycle bin and then click OK
Method 3: Try to empty recycle bin using command prompt
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator.
2. Type the following command and press ENTER:
rd /s /q C:\$Recycle.bin
https://linustechtips.com/topic/15741-recycling-bin-wont-empty-c/#findComment-177536
Nevermind, I deleted the recycling bin folder on my data drive. I have no idea why there was one there in the first place O.o
https://linustechtips.com/topic/15741-recycling-bin-wont-empty-c/#findComment-177537
  • 3 weeks later...
Alternatively, you can right click your C drive and select properties. From there, click "disk cleanup" and after a minute or two, you can select what you want to get rid of in the dialogue box, and select "ok".
It's a great way to keep that disk clean :]
https://linustechtips.com/topic/15741-recycling-bin-wont-empty-c/#findComment-245509
