AIO Fans
Go to solution Solved by TPCEA,
39 minutes ago, kazimalizaidi said:
i don't know much about it the DC website states that LT720 are quipped with 3x FK120 so i have 3 of them on my aio they came with the box
https://www.deepcool.com/products/Cooling/cpuliquidcoolers/LT720-WH-360mm-Liquid-Cooler-1700-AM5/2023/16749.shtml
I am correct. The FK120 on the LT720 is better than the ones sold separately. The P12 Max is better than both with AF 137.69 & SP 4.35, and the Phantex T30 is much better.
Separate FK120 fans
Fan Airflow 68.99 CFM
Fan Air Pressure 2.19 mmAq
LT720 FK120 fans
Fan Airflow 85.85 CFM
Fan Air Pressure 3.27 mmAq
I have a DeepCool LT720 AIO I would like to replace the DeepCool FK120 fans with Phanteks T30 is it a good choice or am I wrong?
I am also attaching both fan's specifications, what I see is FK120 have supreme airflow because of higher CFM compared to Phanteks T30
Intel® Core™ i5-14600K - Zotac RTX 3060 12GB Twin Edge OC - MSI MAG B760 Tomahawk WiFi DDR4 - Corsair Vengeance RGB Pro 16GB 3600MHz - Corsair CV Series 650 Watt 80+ Bronze - Samsung 970 EVO Plus 500GB NVMe - Cooler Master MB511 ARGB - DeepCool LT720 360mm
https://linustechtips.com/topic/1572964-aio-fans/
the number shown on the site is for max rpm, the t30 has better airflow across the low and mid range
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1572964-aio-fans/#findComment-16433095
Phanteks T30 is the absolute goat for PC fans
But, the price of replacing 3 fans for your DeepCool LT720 would be astronomical, even with 3-pack (USD 85 based on Amazon)
I would suggest to buy some really really great but cheap and reliable such as Arctic P12 Max
Based on Hardware Canucks YouTube test, it's one of the top best performing AIO fans with cost USD10 each
(USD 46 for 5 pack, you can keep the spare 2 or replace the front / rear fan if you want for max usage)
I have been using P12 Max for Air Cooler and rear fan, best decision I have ever made
YouTube test comparison for reference
P.S.
Arctic P12 Max doesn't have PWM plug for daisy chain (most high end performance fans doesn't have it) but the cable is long enough to be plugged around the motherboard. So you're gonna need some 3 way fan splitter or fans controller to be plugged in
P.S.S
Arctic also has P14 Max (140mm) variant if you really wanna go full arctic for your PC fans case
Edited by ImWilly
Additional Info
My System: Ryzen 7800X3D // Gigabyte B650 AORUS ELITE AX // 32GB 6000MHz DDR5 Silicon Power Zenith CL30 // Sapphire Pulse AMD Radeon RX 7900 XT OC with mod heatsink on the metal plate  // Phanteks P300A  // Gigabyte Aorus GEN4 7300 PCIE 4.0 NVME // Kingston NV2 Gen4 PCIE 4.0 NVME //
Seasonic Focus GX-850 Fully Modular // Thermalright Frost Spirit 140 Black V3 // Phanteks M25 140mm // Display: Bezel 32MD845 V2 QHD // Keychron K8 Pro (Mod: Gateron black box ink; Tape mode on PCB and Keycaps) // Razer Cobra Wired Mouse // Audio Technica M50X Headphone // Sennheiser HD 650 // Genius SP-HF180 USB Speaker //
And Laptop Acer Nitro 5 AN515-45 for mobility
Phone:
iPhone 11 (with battery replaced instead of buying new phone for long term and not submitting (fully) to Apple Lord
https://linustechtips.com/topic/1572964-aio-fans/#findComment-16433102
T30 is 100CFM at full speed. I think you would be better off with push/pull using cheaper fans.
I mean, they are pretty decent and all for a consumer fan, but if you want real performance, 120x38 is where you should be looking.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1572964-aio-fans/#findComment-16433239
You listed the lowest setting of the T30. On "performance" (middle), the T30 has better AF than that fan, and slightly weaker SP. On "Advanced" (high), it crushes this fan with ease. There are several fans that are "supreme", including the T30 - this is only above average. If you want to cool a rad, the T30 is one of the best options.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1572964-aio-fans/#findComment-16433402
what about p12max i mean they are cheaper will the perform better than fk120's?
https://linustechtips.com/topic/1572964-aio-fans/#findComment-16434691
If it's the FKs that DC sells separately, the P12 Max will be stronger.
I don't know if DC mounts them on AIOs but, if they do then it's likely that they are stronger than the FKs sold separately. I say this because the FCs that are sold separately are weaker than the ones on AIOs.
https://linustechtips.com/topic/1572964-aio-fans/#findComment-16434723
https://linustechtips.com/topic/1572964-aio-fans/#findComment-16434934
Separate FK120 fans
LT720 FK120 fans
https://linustechtips.com/topic/1572964-aio-fans/#findComment-16434977
Separate FK120 fans
LT720 FK120 fans
thank you I will get the p12 max as they are cheaper and that would be a decent upgrade over the fk120, t30 would be a bad choice to replace fans cause I can get another lt720 aio with that money
https://linustechtips.com/topic/1572964-aio-fans/#findComment-16435154
