Need some help regarding my system
Solved by Needfuldoer,
18 minutes ago, KuroKami07 said:luminous inverter eco watt neo 1050
Make sure it's in UPS mode, with Eco mode disabled. It could be taking too long to switch between mains voltage and the battery, interrupting power just long enough to reset your computer.
From what I can tell it supports a maximum sustained load of 750 watts, so unless you've got lots of other stuff plugged in it should be fine.
