PCPartPicker Part List: https://fi.pcpartpicker.com/list/Qjy9mD
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  (€182.20 @ Proshop)
CPU Cooler: be quiet! Pure Rock LP CPU Cooler  (€49.00)
Motherboard: ASRock B760M PG Lightning/D4 Micro ATX LGA1700 Motherboard  (€106.90 @ Datatronic)
Memory: Kingston FURY Beast 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€44.00)
Storage: Lexar NM620 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€65.00)
Video Card: Gigabyte WINDFORCE OC GeForce RTX 4060 8 GB Video Card  (€325.00)
Case: Jonsbo C6 MicroATX Mini Tower Case  (€44.00)
Power Supply: MSI MAG A650BN 650 W 80+ Bronze Certified ATX Power Supply  (€62.00)
Case Fan: ARCTIC P12 Slim PWM PST 42.1 CFM 120 mm Fans 3-Pack  (€22.00)
Total: €900.10
Generated by PCPartPicker 2024-05-23 16:54 EEST+0300
https://linustechtips.com/topic/1571288-900-small-pc-build/#findComment-16418235
Total: €900.10
Problem is that cooler isnt enough for a 12600k.
Either the case needs ro be different or a bettrr cooling solution needs to be found.
If that case HAS to be it the johsnbo CAN do 120mm aios which are better than that but well also not a lot
https://linustechtips.com/topic/1571288-900-small-pc-build/#findComment-16418260
PCPartPicker Part List: https://fi.pcpartpicker.com/list/rg9vyg
CPU: AMD Ryzen 5 7500F 3.7 GHz 6-Core OEM/Tray Processor  (€180.00 @ Proshop)
Motherboard: ASRock B650M-H/M.2+ Micro ATX AM5 Motherboard  (€106.90 @ Datatronic)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL32 Memory  (€129.08 @ Proshop)
Video Card: PowerColor Fighter Radeon RX 6650 XT 8 GB Video Card  (€276.90 @ Datatronic)
Case: Jonsbo C6 MicroATX Mini Tower Case  (€42.90 @ Datatronic)
Power Supply: be quiet! System Power 10 550 W 80+ Bronze Certified ATX Power Supply  (€55.90 @ Datatronic)
Total: €927.68
Generated by PCPartPicker 2024-05-24 01:06 EEST+0300
this maybe?
https://linustechtips.com/topic/1571288-900-small-pc-build/#findComment-16418616
