Just now, ariaselm said:
Hey guys ,i have a gigabyte rtx 4080 super aero oc, with ryzen 7 7800 x3d , but i cant get above 160fps on destiny 2 in the tower , idk where i went wrong
What resolution and in game settings are you playing at?
Is the graphics card running at full clockspeed and usage?
https://linustechtips.com/topic/1567888-need-help/#findComment-16389770
2 minutes ago, ariaselm said:
3440 X 1440p and i always around like 90s usage when i play , idk if its running at full clock speed
Then you gotta drop resolution or ingame settings it seems like.
Check clockspeeds, this can be seen in MSI afterburner. Should be between 2700 and 3000mhz for the 4080 Super.
Are there any videos you have seen with similar specs to yours that get over 160fps at 3440 X 1440p with same in game settings in the tower?
https://linustechtips.com/topic/1567888-need-help/#findComment-16389775
