Didn't work /:
I would recommend using a modified version of a osx a made a nice tutorial on the forum for said thing with amd, just dont use the amd bootflag, just do graphicsenabler=yes
http://linustechtips.com/main/topic/155818-how-to-hackintosh-with-amd-fx/#entry2077028
I would recommend using a modified version of a osx a made a nice tutorial on the forum for said thing with amd, just dont use the amd bootflag, just do grapphicsenabler=yes
The download is taking so long ):
My build is on my profile. I try to run mac osx installer usb drive following the linus tech tips one, I get an error : SMC::smcInitHelper ERROR: MMIO regMap == NULL - fall back to old SMC mode.
Maybe try:
npci=0x2000 GraphicsEnabler=No -x cpus=1 (and maybe add -v)
Business Management Student @ University St. Gallen (Switzerland)
HomeServer: i7 4930k - GTX 1070ti - ASUS Rampage IV Gene - 32Gb Ram
Laptop: MacBook Pro Retina 15" 2018
Operating Systems (Virtualised using VMware): Windows Pro 10, Cent OS 7
Occupation: Software Engineer
don't try this @
Senor Potato
cpus=1 is a bad command don't use it
I know, but depending on the CPU it is needed to get to the install setup
I used the unibeast method instead and it worked, I wonder why myHack doesn't work
EDIT: All I entered was PCIRootUID=0 and GraphicsEnabler=Yes no -v or npci=0x2000 or anything
It really depends on your system
