Hi there! I'm planning on building my first PC soon which is very exciting, but the process of choosing all the parts has been a bit overwhelming. If anyone can look over what I've chosen so far and offer advice, I would greatly appreciate it! Questions are also welcome, thanks : )
Budget (including currency): Around $1400 CAD
Country: Canada
Games, programs or workloads that it will be used for: Gaming including Minecraft and The Sims franchise games with mods/shaders, light video editing
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I'm not super concerned about aesthetics, but I'd like a white case (on the small side since I don't have a lot of room). I'll be buying the parts within the next week. My main goal for the PC is to have the best performance for my budget and that it'll last me a good couple of years!
PCPartPicker Part List: https://ca.pcpartpicker.com/list/9xTqMV
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  ($201.96 @ shopRBC)
CPU Cooler: Thermalright Peerless Assassin 120 SE WHITE ARGB 66.17 CFM CPU Cooler  ($41.90 @ Amazon Canada)
Motherboard: ASRock B760M Pro RS/D4 WiFi Micro ATX LGA1700 Motherboard  ($149.61 @ Vuugo)
Memory: TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($77.42 @ Vuugo)
Storage: Kingston NV2 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($79.98 @ Amazon Canada)
Video Card: ASRock Challenger OC Radeon RX 7800 XT 16 GB Video Card  ($669.99 @ Amazon Canada)
Case: Azza Spectra ATX Mid Tower Case  ($90.11 @ Amazon Canada)
Power Supply: Deepcool PM750D 750 W 80+ Gold Certified ATX Power Supply  ($89.99 @ Amazon Canada)
Case Fan: Thermalright TL-S12W X3 47.6 CFM 120 mm Fans 3-Pack  ($21.08 @ Amazon Canada)
Total: $1422.04
https://linustechtips.com/topic/1567504-help-with-first-time-build/
Look out for any deals,
it's a pretty decent list tbh.
Consider these parts, but you can go with yours, I included different case, PSU and SSD.
Memory: *TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($77.42 @ Vuugo)
Storage: *TEAMGROUP MP44L 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($94.99 @ Newegg Canada)
Video Card: *ASRock Challenger OC Radeon RX 7800 XT 16 GB Video Card  ($669.99 @ Amazon Canada)
Case: Montech AIR 903 BASE ATX Mid Tower Case  ($74.99 @ Newegg Canada)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Canada Computers)
Total: $1420.85
Generated by PCPartPicker 2024-04-20 16:55 EDT-0400
I included higher quality PSU and SSD, the case is up to you, I think the one I included should come with 3 pre-installed fans.
For SSD, look for either of the SSD that's included in the parametric filter, if your budget allows it, they're all great budget SSDs.
current PC:
PC configs I used before:
Yo, @Why_Me, can u check if the MB is good? I think it's pretty decent.
current PC:
A 12 or even 10 phase board would be nice but that jumps the price by $100+ CAD hence the reason I dread posting Canadian builds.
https://www.asrock.com/mb/Intel/B760M Pro RSD4 WiFi/index.asp
7+1+1 Power Phase, Dr.MOS for VCore+GT
Total: $1420.85
Awesome, thanks for the explanation!
yeah right, but isn't 7+1+1 decent? it's not an i9 build
current PC:
