Need help setting up drives
Solved by ZROCK,
Q1- The drive should boot just fine. As long as you set the boot drive to the hdd. It might be a little finnickey but you might have to reinstall windows and select keep files.
Q2- Yes just set the boot drive to the m.2 also make sure to delete windows files to avoid any conflict.
Q3- It sometimes takes some work to get old drives with files to work flawlessly on a new system/ existing system but a good old fashioned youtube video should help out.
Q4- EASE US should do just fine if you wanna clone a drive. Ive used it before. A fresh windows install will always go smoother though- Ive gotten windows keys off of G2A in the past.
Hope that helps
