Hello, im ready to buy parts to build my cheap gaming pc, but firstable i need to know will these parts work together, since im not an experienced pc builder. So i have done a little search and i found out that these parts have best value per price (in my region) . Please leave answers so i can make changes to my build if something is wrong. Bugdet is 350€ or 500$.
1)Motherboard: MSI H81M-P33
2)CPU: INTEL® CORE I3-4130 3.4GHZ 3MB LGA1150
3)Gpu: ASUS AMD/ATI RADEON R7 260X 1GB GDDR5 PCIE
4)HDD: TOSHIBA DT01ACA050 500GB 7200RPM SATA3 32MB
5)Case: CODEGEN QORI Q3353-A2 ATX-Q3353-A2
6)Power supply: COOLER MASTER ATX 2.3 THUNDER 600W
7)Ram: CRUCIAL 4GB DDR3 PC12800 CL11 CT51264BA160B
Thanks for your time!
https://linustechtips.com/topic/156725-need-help-bulding-pc/
go amd at that budget. way better value.
what will the system be used for? budget?
there are better psu's out there, but if you cant get others, cm is still a good brand.
the ram is also not the best, but i wont hurt performance much at the same time.
case is personal preference, eventho i'd another one.
do you need that much disk space? if not, get an ssd, it is worth it.
https://linustechtips.com/topic/156725-need-help-bulding-pc/#findComment-2089155
@Erlaps I would go with an amd apu build. If you want to do it yourself I would recommend you to watching this video.
https://www.youtube.com/watch?v=OlCqYyAQE_w
These should be understood as a basic tutorial & follow up guide.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/156725-need-help-bulding-pc/#findComment-2089223
Hello, im ready to buy parts to build my pc, but firstable i need to know will these parts work together, since im not an experienced pc builder. So i have done a little search and i found out that these parts have best value per price (in my region) . Please leave answers so i can make changes to my build if something is wrong.
Please don't repost on a topic you recently posted right here:
http://linustechtips.com/main/topic/156725-need-help-bulding-pc/
I'm merging the threads.
https://linustechtips.com/topic/156725-need-help-bulding-pc/#findComment-2089305
Well ok, but these parts work best for me, i just want to know will these parts work together. System will be used for gaming
https://linustechtips.com/topic/156725-need-help-bulding-pc/#findComment-2089614
amd works better. why do you say that intel works better for you? why do you ask if you dont want people to improve your system?
Sorry, its 350€ or 500$
what does that depend on?
https://linustechtips.com/topic/156725-need-help-bulding-pc/#findComment-2091816
If you have any doubts about them not working together, I'd just get an AMD build like these people are saying. Better for your money too
IdeaCentre K450 Review - My favorite (pre-built) gaming desktop under $1000.
Gaming PC Under $500 = Gaming on a budget.
https://linustechtips.com/topic/156725-need-help-bulding-pc/#findComment-2092598
