If you go for a low enough power system, you could probably passively cool the whole box and avoid sucking in any dust / metal at all.
But it won't be easy.
How much CPU Horsepower do you need to drive the CNC?
Or, what about a fiberoptic cable, and putting the PC in the next room, safe from the metalshop chaos?
https://linustechtips.com/topic/1566869-cnc-plasma-pc-case/#findComment-16382411
