[ Moved to Laptops and Prebuilt Systems ]
Those prebuilt Optiplex machines typically have very small power supplies. (If you're lucky, it's a 360 watt unit with one 6-pin PCIe power cable.)
I wouldn't count on being able to run any video card that requires PCIe power. Cards that only draw power from the slot should be okay.
https://linustechtips.com/topic/1566734-build-help/#findComment-16381390
2 minutes ago, Chris alm said:
The XE3 Optiplex comes with a proprietary 360w power supply without the required 8pin power connector the RX 6600 require.
As mentioned above by @Needfuldoer  A GPU that does not require an external power connector would be your best bet.
A used 1050ti or some versions of the GTX 1650 does not require external power.
Same for the Radeon RX 6400.
https://linustechtips.com/topic/1566734-build-help/#findComment-16381392
