My pc has a bit of a problem with booting. When booting my pc stays on the mother board logo for  a lot of time. When I just made it got in windows in 10 seconds but now it takes more then 50 seconds.
This problem started when I moved the pc a lot.
The specs:
 B560 plus WIFI TUF GAMING;
 32 GB of ddr4 RAM;
 2 TB M.2 SSD;
 600 W power supply;
 GTX 1660 super;
 I9 11900KF;
https://linustechtips.com/topic/1566346-need-help/
What have you tried so far to fix the issue?
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1566346-need-help/#findComment-16378443
Sometimes this happens when your PC has trouble accessing your os or its been deleted. if your pc cant access your os, it just stays stuck in the loading screen. does the loading wheel at the bottom appear in the mobo logo when this happens?
Make sure to mark solutions, as it helps us find people who need help faster. Thanks!
I am human and am therefore prone to error, so I apologize if I make mistakes and I hope you understand.
Have a Nice Day!
https://linustechtips.com/topic/1566346-need-help/#findComment-16378510
