I recently upgraded my GPU from 1650 to 4060.
It was working fine but after playing cyberpunk for some hours, i got some memory error and PC just won't work.
First i got stuck in BIOS loop, after that i tried to reinstall Win and it got stuck in that too.
My PC got fked like this in feb n march too when i used Adobe apps.
I just feel like my PC can't handle load anymore.
It is the ram that is faulty, or SSD.
Maybe the motherboard.
I did memtest before but no issue.
Now i did memory dia and still no problem. Did SFC/scannow , chkdsk too, Said some problem are detected and repaired them.
But still my PC just won't open now.
Can anyone tell me what might be the problem?
My motherboard - Gigabyte H470M DS3H
Processor -i7 10700F
GPU - Asus Dual 4060
Ram - Crucial Basic 16x1 2666mhz
SSD - XPG GAMMIX S5 256GB
HDD - WD 1TB
PSU - MSI 650W
https://linustechtips.com/topic/1565795-need-some-help/
that's a very weird problem. I suggest maybe re-install the CPU even if it worked before! that could cause ram errors. also what exactly happens after booting?
My Daily/Gaming Setup:
  • CPU
    Intel i7-13700k
  • Motherboard
    Gigabyte Z690 Gaming X DDR4
  • RAM
    Kingston Fury 32GB (2x16GB) DDR4 3600MHz CL 16 Renegade RGB
  • GPU
    Asus TUF Gaming 3070 OC
  • Case
    Fractal Torrent Compact
  • Storage
    Kingston Fury Renegade M.2 1TB SSD (BOOT)
    Corsair MP400 4TB m.2 (Game Library...)
  • PSU
    Corsair RM850X 80+ gold
  • Cooling
    NH-D15
  • Keyboard
    Logitech g915 TKL
  • Mouse
    Logitech G pro X superlight
  • Sound
    Behringer UM2
    UA Apollo Duo X (I noticed I don't have a Thunderbolt port after purchase 😢)
    Behringer UMC1820 (main)
  • Operating System
    Win 11 pro
My Home Server:
OS: TrueNAS Scale
CPU: i9900k
Ram: Corsair Vengeance LPX Black 32GB (2x16GB) 3200MHz  CL16
Motherboard: Asus gaming z390-f (6sata connectors)
Cooler: Corsair Hydro H80i v2 120mm AIO
PSU: Corsair 600w 80+ bronze
Storage: 3*4TB Seagate Ironwolf HHD
Boot: 2* M.2 NVMe Gen 3 500GB
Case: Cheap fractal case with HDD mounts
https://linustechtips.com/topic/1565795-need-some-help/#findComment-16374466
