Help Deciding GPU.
By
Brokkoli
in Graphics Cards
in Graphics Cards
Solved by Catzzye,
Out of those three, I'd recommend going with 4060, it's not a bad price all things considered.
As you say if you don't game too much it would be more than enough, and if you do end up gaming in the future it should handle everything for a while now (tho depends a bit on the rest of the system).
Good luck!
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
