I have a GPU that gets really hot TJmax temps (110c) 70c Temp and Idk what to do.  To be clear I have had no instability and it has worked fine but I am worried it is going to brake. Should I try to do something about it I have thermal paste but no thermal pads to add to if I try to take it apart I am worried I have to replace them. I know they're cheap but I am a broke student who will basically have no money till next summer I will get a job again.  Lmk if I am over reacting and it's fine.  I will show some screen shots.
My specs are
RX 5700 XT Phantom Gaming
i5 10400f
Gigabyte B460 Mobo
32 GBS Ram
2TB storage
image.thumb.png.29dde52e4e895cefe8a78e4bb4755d20.pngimage.thumb.png.6f9952e92c6d3446edbb6c49faf36fe1.png
My specs are
i5 10400f
Gigabyte B460 Mobo
32 GBS Ram
2TB storage
Time to repaste, the 5700XT is nearly 5 years old...
Just now, Christopher_829 said:
Mine is like 6 months old though it was stupidly cheap when I got it new. I I re paste it do I have to replace thermal pads?
New ? How that ? Production was stopped maybe 3 years ago.. Even if it collected dust in a hangar since, paste still dried
You can also change pads but it's not required unless your VRAM temps are also bad
It was on Amazon seriously brand new in box. VRAM Temps are fine so I suppose that does not need to change.
My specs are
i5 10400f
Gigabyte B460 Mobo
32 GBS Ram
2TB storage
hold on
you said its an RX 5700 XT Phantom Gaming
which is an Asrock GPU
but in the pictures it says Asus
what is going on here?
2 minutes ago, Alireza said:
hold on
Omg fantastic question I was hoping someone else knows
I thought maybe ASUS owned AS Rock so they show up the same
2 hours ago, Alireza said:
hold on
It's Asusrock maybe 😄
Anyway OP should repaste it!
yeah
you need to repaste that
and also remember that 5700xt is a very power hungry chip and it will get very hot
so don't be afraid if temps are a little higher than you expect even after a repaste
