Hi There,
Just bought RTX 4080S, did i need to replace my current PSU Corsair Hx 750 with the better one ? I had Anxiety with pcie converter from the brand, worry to cause fire and the aesthetic mehhh…
or i just buy corsair 12vhpwr ? Is it still support old psu like i had ?
https://linustechtips.com/topic/1564158-psu-recommendation/
Use whatever you have, even if you have an antic HX chances are it's fairing well but don't take me word fully on that. I know some people run their PCs on crappy house grid electricity sources.
You can use a converter, it might have been included in the box of the card.
https://linustechtips.com/topic/1564158-psu-recommendation/#findComment-16362473
47 minutes ago, seon123 said:
Which of Corsair's 4 different HX series is the PSU from? When did you get it?
Sorry, are there multiple Corsair Hx 750?
what is mean by Corsair 4?
I want to replace my Zotac Converter with Corsair. Because its ugly and it bend near the case.
So i ask your’s opinion  about using new corsair converter with old Hx750
https://linustechtips.com/topic/1564158-psu-recommendation/#findComment-16362485
25 minutes ago, Einzbern said:
Ooh ic. Mine was Hx80+ platinum
Then I won't worry, should work good
https://linustechtips.com/topic/1564158-psu-recommendation/#findComment-16362522
