NEED HELP GTA 5!!
Go to solution Solved by venomtail,
I would start with a clean slate. Uninstall the game, wipe the folder the game was installed to so when you install the game again a new folder has to be created, along with the rockstar launcher and its folder.
Whats up mates!
So let me explain, i have been having issues with gta 5 and this is not the first time because this has been happening to me for years and with luck or randomly the game would choose to work. This is the game that has ever given me the most difficulty, pain and headaches and i have watched tons and tons, TONS AND TON of videos but non, literally non ever worked for me. Its like im cursed with this game or something lol.
So i get alot and diffrent errors when launching the game and if i manage to fix it another one would comeup again!
I have installed every single driver i have and from the Internet, in fact i have updated, chnaged windows just because of it but as i said, WITH LUCK OR RANDOMLY THE GAME WOULD CHOSE TO WORK.
Today i was playing and when i quit and came back the game wasn't launching, like no response, i click the executable but it would show anything i have tried compatability, admin mode bla bla but nothing. So i used debug viewer to see thats up and i got this 20240321_103147.thumb.jpg.40b426446b681f8e5876ec04c5b77bcb.jpg
 I have no idea what most of does means but who knows.
I downloaded diffrent versions of the game to see but its all the same. I removed DINPUT8.DLL to see if it would make a diffrence but nope. I have installed and removed my mods but nope.
Ohh and i have reinstalled the game like a GAZILIAN times, at this point i know the games files more than some worker in R* lmao 😂.
https://linustechtips.com/topic/1563609-need-help-gta-5/
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1563609-need-help-gta-5/#findComment-16358335
Probably uninstall the game and then wipe the folder and delete it entirely, if it doesn't work when if you used steam there is a button in that says verify integrity and would hopefully reinstall any corrupt or missing files, now for epic I'm not 100% sure if there is an option for that I could be wrong though.
Gigabyte B560m DS3H AC | Intel i5 11400f | AMD RX 6800 16gb | T-Force TUF 16gb (2x8) 3200 mhz
Samsung 27' CRG5 Freesync, 144hz | Lenovo 21.5' LI2264d, 75hz
https://linustechtips.com/topic/1563609-need-help-gta-5/#findComment-16362659
I did that but i had to download an update before it worked
https://linustechtips.com/topic/1563609-need-help-gta-5/#findComment-16363334
so it worked because of verifying the integrity or because you installed an update?
https://linustechtips.com/topic/1563609-need-help-gta-5/#findComment-16363566
After reinstalling the game and applying update, i created a note so i could remember it later>
install direct x
install redistributions 2005-2022
install files, if failed:
uninstall the game (not delete, uninstall it)
install the game back and change the file name i.e GTA 5 to GTA V.
if failed, install build 1.67 update
install build 1.67 update root files
install the updates as well.
https://linustechtips.com/topic/1563609-need-help-gta-5/#findComment-16364437
install direct x
oh wow alright well im glad you found it out!
https://linustechtips.com/topic/1563609-need-help-gta-5/#findComment-16364855
