8 minutes ago, Shadowstriker said:
,is it go to use zip ties etc in the back?
I just use Zip Ties, If you feel fancy or you like to work on your system often, I'd recommend velcro ties, as those produce less waste, but are more expensive.
English is not my first language, so please excuse any confusion or misunderstandings on my end, also I like to edit my posts a lot.
F@H-Stats
The Rigs:
Xenon:
CPU: 2x Xeon E5 2690 V3
RAM: 64GB DDR4 2133 RDIMM
MoBo: Supermicro X10DRi-T4+
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
RAM: 48GB DDR4 3200 UDIMM
MoBo: ASRock B550M Pro4
The Laptop (Lenovo Legion 5 15IAH7):
CPU: Core i5 12500H
RAM: 16GB (2x8GB) DDR5-4800
GPU: RTX 3050 Ti mobile
OS: Windows 11 Home
The Tablet:
Dell Latitude 7212 Rugged Extreme Tablet (Core i5 8350U/8GB RAM)
OS: Windows 11 Pro
32 minutes ago, Shadowstriker said:
Im Curios as to what the best way to manage your cables are,is it go to use zip ties etc in the back? Also I would like to make the interior ascetically pleasing and thought about getting one of those white rgb psu cables worth it or no?
If you haven't bought the PSU you might consider a white model as they usually come with white cables.
The problem I have with zip ties is the need to replace them when there are changes. I generally prefer velcro straps but have been known to use twist ties in a pinch 🙂.
Reusable plastic zip ties / Reusable Silicone zip ties / beaded cable tie
Refresh before you reply
