PC Advice
Go to solution Solved by Tetras,
Proprietary parts and limited upgrade potential are the only downsides I can think of, but those problems obviously depend on which mini PCs you buy and if the PCs are replaced frequently it probably doesn't matter anyway.
Would recommend more RAM and I'd actually prioritise that over even the CPU.
Ahoy all.
I'm helping my boss with picking out new PCs for the front desk and office. The image below shows the minimum specs the company is looking for. They are, as you can see, pretty lightweight. I'm certainly recommending something with more horsepower.
I'm thinking that a mini-pc would be a great option. 90% of what they do is cloud-based. So they really only need good internet speeds, and decent processing. They need to manage some spreadsheets and Word docs, but nothing too crazy. They need a small form factor for the front desks, and you don't get much smaller.
What are the possible downsides that I might not be considering?
Are there any brands you'd recommend over others?
Dan
https://linustechtips.com/topic/1562786-pc-advice/
https://linustechtips.com/topic/1562786-pc-advice/#findComment-16352672
Well, I just stumbled on Paul's Hardware build for his sister, a really small and not noisy ITX build, maybe that could be an inspiration for your office build.
It's obviously overpowered based on the specs below for your office use case, but
Are you aiming for pre-build?
Specs:
CPU: Ryzen 8700G -> You can change to 5600G (older AM4 platform) or i3-12100
Mobo: Asrock A620I Phantom Gaming (this is for AM5, for AM4 you need to look for either B550 or A520)
CPU Cooler: ID-Cooling IS-47-XT
RAM: G.Skill Flare X5 32GB (KIT 2x16GB)
Storage: Kioxia BG4 NVME 1TB 2230
Case and PSU combo: InWin Chopin MAX, 200W PSU
Basically, what he does in this build is using ITX form factor (motherboard and case), and utilized Integrated graphics instead of dedicated GPU (CPU with "G" on Ryzen or Intel CPU without "F"), paired with low profile CPU air cooler.
My System: Ryzen 7800X3D // Gigabyte B650 AORUS ELITE AX // 32GB 6000MHz DDR5 Silicon Power Zenith CL30 // Sapphire Pulse AMD Radeon RX 7900 XT OC with mod heatsink on the metal plate  // Phanteks P300A  // Gigabyte Aorus GEN4 7300 PCIE 4.0 NVME // Kingston NV2 Gen4 PCIE 4.0 NVME //
Seasonic Focus GX-850 Fully Modular // Thermalright Frost Spirit 140 Black V3 // Phanteks M25 140mm // Display: Bezel 32MD845 V2 QHD // Keychron K8 Pro (Mod: Gateron black box ink; Tape mode on PCB and Keycaps) // Razer Cobra Wired Mouse // Audio Technica M50X Headphone // Sennheiser HD 650 // Genius SP-HF180 USB Speaker //
And Laptop Acer Nitro 5 AN515-45 for mobility
Phone:
iPhone 11 (with battery replaced instead of buying new phone for long term and not submitting (fully) to Apple Lord
https://linustechtips.com/topic/1562786-pc-advice/#findComment-16352695
Well, our current PCs are the same as when they opened the location, 10 years ago. So frequent replacement isn't an issue, LOL.
https://linustechtips.com/topic/1562786-pc-advice/#findComment-16352893
