I have a lot of power outages and i want to choose a UPS for my unit. What kind of ups do You recommend for a 750W psu. My PC consumes like 500W and my monitor i don't think it goes over 100W... keyboard and mouse are both Low wattge so no worry about that. My buget is a maximum of 400 dollars
https://linustechtips.com/topic/1562102-ups-recommandations/
Extremely happy with my current model, the CyberPower CP1500PFCLCD.
$220 or so retail so well under budget. Runs my 7800x3d/4090/LG C2 system at the desktop for 30-40 minutes on battery and the software is miles better than what APC has for consumer units.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1562102-ups-recommandations/#findComment-16347370
Thanks soo much. I will look into it
https://linustechtips.com/topic/1562102-ups-recommandations/#findComment-16347394
Could i maybe go with the CyberPower CP1300EPFCLCD with 1300VA/780W, AVR?
https://linustechtips.com/topic/1562102-ups-recommandations/#findComment-16347405
That would work just fine, yes.
https://linustechtips.com/topic/1562102-ups-recommandations/#findComment-16347423
