Recently, my PC crashed while I was playing a game, and since then, it hasn't been able to boot into Windows 11. Upon startup, it shows the screen where I can access the BIOS, then it loads briefly before entering another screen that says "Preparing automatic repair." After that, it restarts on its own. Sometimes, after several restarts, I can access the blue troubleshooting menu. However, none of the options in there seem to resolve the issue.
I was advised to update the BIOS and reinstall Windows. I've successfully updated the BIOS to the latest version. However, when I select the SSD where I've installed the Windows Media Creation Tool from the boot menu, it just restarts and returns to the "preparing automatic repair" loop.
Any help would be greatly appreciated. Thank you.
https://linustechtips.com/topic/1561338-i-need-your-help/
in troubleshooting mode, did you open an admin cli and enter: powercfg -h off  ?
it can be a fubar hibernation\fastboot file that's totaly garbage and crashes your system booting, since it tries to load the garbage hibernated system..
it can be powercfg /h off ..
https://linustechtips.com/topic/1561338-i-need-your-help/#findComment-16341861
SSD might be bad. You can try clearing the SSD. Secure erase or even using the Windows USB (repair disk) to repair the installed windows.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1561338-i-need-your-help/#findComment-16341862
I would start by trying with a fresh SSD/HDD to see if that gets you any further than where you've got to already. Install a fresh Windows Media Creation Tool ISO on a USB, See if it will let you install onto the new drive. If that works, your original drive was corrupted.
You could also use another computer to create a new (and more up to date) windows media creation tool ISO onto your removable storage. Make sure you wipe it first, and download the whole setup onto the removable storage, instead of just using it as the install path
If this doesn't get you any further, and you're using a SATA SSD, try using a different SATA slot, and likewise with M.2 Drives.
If any of this doesn't work, I would attempt to reseat the CPU. Very occasionally, and particularly with pin based CPUs, this issue could be caused by a bad contact on the socket, and reseating it could solve this.
Hope you manage to get it sorted
https://linustechtips.com/topic/1561338-i-need-your-help/#findComment-16341879
