im running a gtx 760 gpu, on a dell mb. with a intel lga 1155 2500s 4 core 2.7 or .5., can i upgrade a lil bit to get more performance on my gpu. I'm literally struggling on some game..... some. the question if i can get a better gpu for good price to not bottle neck cpu, im talking 190 to 200$ range, on gpu for now. the intel a380 is on par wit my budget but with its own problems wit games. idk... im liturally on a low money budget........ be nice guys!!!!
https://linustechtips.com/topic/1560566-i-need-help/
You can upgrade the gpu,what do you want AMD or Nvidia. If you want to upgrade the cpu you can i think get an i7 3770k if im not wrong,
The 500 series amd cards or 10 series nvidia cards would be the group for you, anything higher is a bottleneck bro. Rx 570, rx 580 (8gb vram variants) or gtx 1060, 1080 (6gb vram variants )
Upgrading the cpu only wouldn't provide you with much improvement so upgrade the GPU and later if you can then upgrade the cpu too.
https://linustechtips.com/topic/1560566-i-need-help/#findComment-16336460
Honestly... If you can find a cheap VEGA64 or 1080ti that's what I would get, about the highest performance bracket I would go to
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1560566-i-need-help/#findComment-16336468
