2 minutes ago, Vaczil said:
When i host a server or a game my friend always expriences some type of lag, his internet connection is perfect i checked so as mine
when he hosts i don't get any type of lag or ping issues
any idea why this might happend...?
What are your respective Internet plans? Sounds like his upload is better than yours.
https://linustechtips.com/topic/1560332-hosting-issue/#findComment-16334755
5 hours ago, Vaczil said:
Mine is 1GB, his is 500MB if im not wrong.
He should do a tracert IP to your server from his pc to see if anything is delaying the data transfer.  And you should do one from your server too his IP or router adress.. or his ISP router adress. to atleast see if anything makes an issue on the return data as well.
what you can do, is make a vpn so no data is scanned between you.
remember regardless of yours and his internet plans, since you are private ppl they are usually best effort, so if all customers are sharing the ISP uplink manages to maximize the bandwith, you will have a slower link.
Internet speed is always limited by the slowest link in the chain, if that is an overworked router/firewall or service interlink is hard to say, but tracert is a start to see what responds on the way from him to you..
https://linustechtips.com/topic/1560332-hosting-issue/#findComment-16335106
