GPU VGABIOS FLASH is not the same as the model? Need help PLS
Go to solution Solved by DoctorNick,
24 minutes ago, tls123 said:
Hello! Lately I have been having problems with my 2nd display monitor to which I believe is not being detected by the GPU. I have then tried ti Flash the Bios to which I have followed a Youtube video online, all procedures seems to be relatively simple but then I had an obstacle. My Gpu is a Sapphire Pulse 4gb RX570, it shows in the gpu-z, and everywhere else, including the physical stickers on the graphics card. When I was going to flash it with the latest available files however, it stated the P/N was not compatible, I tried to download all the 5 models available for the 4gb SAPPHIRE RX 570 Cards and tried each of them but to no avail. I thinked for a second and then searched for the existing P/N and found that my GPU has the file for an RX 470 NITRO OC by Sapphire. I am very confused and need help, but then it was 3 am and I am dumb so my monke brain went with the latest 470 OC driver file and proceeded to flash my GPU with that, it let me flash the GPU however after restarting, I was able to boot into windows before green screening. I hope I am not fucked yet. I am currently using the onboard graphics to ask for help. Thank you very much.
I really appreciate the input/help as I have really no means of buying a new/used graphics card. This Graphics card was also just a second-hand buy and I've used it for like 3 months. Pls send your Wisdom and Knowledge.
https://www.techpowerup.com/vgabios/190672/sapphire-rx470-4096-161012 this is the P/N that was installed in my GPU and this is
the GPU that I have https://www.techpowerup.com/vgabios/191558/sapphire-rx570-4096-170306
Did you save a copy of the VBIOS before flashing? If not, then this might be the one. https://www.techpowerup.com/vgabios/191558/sapphire-rx570-4096-170306
You can still see the card in device manager right? If yes. Try flashing the BIOS using this method:
This is a written version of the same method, plus one using CMD. (you might need CMD version in order to get this working):
https://www.techpowerup.com/forums/threads/how-to-recover-from-a-bad-video-bios-flash.265939/
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT with custom 3D printed AIO mount, X62 | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15
