Building first pc
15 minutes ago, Jeckle18 said:Budget (including currency): $2100
Country: United States
Games, programs or workloads that it will be used for: Vr, most Triple A games
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): build lid is on https://pcpartpicker.com/list/vJrdz6. Just looking for advice if any parts should be swapped out of list before ordering the parts due to incompatibility for either size or hardware limitations. Any advice would be appreciated.
I would go with something like this instead.
Case needs an 140mm exhaust fan so buy this seperately.
This configuration dramatically improves performance in games. Dont overspend on fans and AIO's.
Even buying a windows licence for 140 bucks is madness.
https://pcpartpicker.com/list/FM679c
