Best Corsair AIO right now?
Fluuwu
Hey guys!
I'm still in my planning phase for my white pc build, and I am currently looking for the best WHITE corsair AIO to get right now. (240mm, preferable below 200 bucks)
Any recommendations?
There are better options than Corsairs generic and overpriced units. That is, if you care about performance vs. white and RGB.
I am specifically looking for Corsair units, since I want the same fans everywhere.
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
You can also buy a better AIO than a corsair one and put the fans you want on it
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
true, fair point... in that case: what AIO would you recommend in a price range of around 150 bucks?
33 minutes ago, Fluuwu said:
what about the Cooler Master MasterLiquid ML240L V2?
It’s the same price as the Deepcool lt520 and I think the deepcool looks better
Current parts list
Probably a deepcool or arctic AIO
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
I've heard that Deepcool AIOs can get very loud tho...
Not too sure, I've never owned one myself
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Basically, look for any AIO that has a long lifespan pump that can move a lot of water and is not in the rad. Make sure the rad is good and the tubes are minimally porous. The fans are irrelevant, so don't worry about them. Once you've got it, buy the strongest Corsair fans that match your esthetic. In other words, static pressure above 4 mmAq and high airflow is also a good idea, but keep in mind that usually higher pressure comes with more noise.  Still, if you want the best results, that's what you need.
Set your pump to a constant speed. Make sure tubes exit the side or top of the water block to prevent air build up. Mount the rad on the front or side, preferably with tubes down so that the air gets trapped in the far end of the rad. If your case is large, you should pay attention to tube length, and you may need to use a vertical mount if you have a long GC. If the pump is mounted on the tubes and you can have it be lower than the junction of the tubes and rad, you can also do tubes up, or top mount.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
