My cpu core speed drops to base when playing apex helppp
To lock the MSR turbo power limits, clear the Disable Controls box and then check the Lock box in the Power Limit Controls section.
Also check the Speed Shift box since your computer might be using that throttling method. Your video was good but I needed to see the TPL window so I could monitor that for any changes to the power limits.
If you are still having problems turn on the Log File option on the main screen before you start playing a game. Attach a log file to your next post.
Your testing shows that turbo boost is being disabled. Intel has created several methods to control this so that is why you have to do some testing to find out what method is being used. Check the Limit Reasons window to see if any reasons for throttling are reported there when this happens.
Post a screenshot of the FIVR window.
PS - I would uninstall Norton in a heartbeat.
When both the MSR and MMIO power limits are locked, you should see two yellow lock icons on the left side.
