Hello,
I have a gigabyte B760 DS3H AX DDR4
With an i9-13900KF processor (stupid combo I know 😅) but I have a light on the motherboard that is red and it is marked CPU. Does anyone know what it means?
It is in a cluster of 4 lights that are marked VGA, CPU, BOOT, and DRAM
The light are located by the CMOS battery.
(See attached Photos)
Sorry the camera doesn't show where the light is very well.
MT
Jamie
https://linustechtips.com/topic/1557751-what-does-a-cpu-light-mean/
It means there's a problem with the CPU.
From the manual that CPU seems supported from the stock BIOS version so it's unlikely it's that it requires an update.
Firstly clear CMOS just in case.
If that doesn't help take CPU out, check for any bent pins/debris/dirt on the contacts, reinstall and ensure proper cooler mounting.
F@H
GPD Win 2
Does the PC boot normally or fail to boot?.
 Main Desktop
CPU: Intel Core i7-14700KF
CPU Cooler: Arctic Liquid Freezer III A-RGB
MB: ASUS ROG STRIX Z790-F Gaming Wifi II
RAM: 32GB(2x16GB) Team T-FORCE Delta RGB 6000MHz DDR5
GPU: ASUS ROG STRIX RTX 4070ti 12GB
STORAGE: 2.048TB Kingston KC3000, 2TB Crucial T500, 250GB Samsung 850 Evo, 1TB Samsung 970 Evo Plus, 240GB WD Green M.2 SATA SSD
CASE: Montech King 95 Pro
PSU: Be Quiet! Straight Power 12 1000W
OS: Windows 10 Home
Monitor: Samsung Oddessy G6 27" 1440p, Viewsonic VX2455 144Hz
Mouse: Logitech G502 Lightspeed Wireless Mouse
Keyboard: ASUS Flare II Animate
Headphones: HyperX Cloud Alpha S Black
Microphone: HyperX Quadcast S
https://au.pcpartpicker.com/user/johnno12/saved/4HDc4D
1
Laptop:
Dell Inspiron 15-5000
CPU: i5-8250U Quadcore with hypertheading
GPU: AMD Radeon 540 4GB Hybrid Graphics
Storage: Micron 1100 SATA 256GB SSD
OS: Windows 10 Home
1
Ok how do I clear the CMOS
3 hours ago, jimbo18 said:
Unfortunately still have the light so I think the CPU may have been damaged in shipping. 😭
Remove the CPU from the motherboard socket.
Inspect the motherboard socket for any damage / bent pins.
Inspect the bottom of the CPU for signs of scratches / damage.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
No bent pins and no scratches.
The box arrived pretty beat up and in a jiffy bag so I am returning it as I think the internals are broke😭PXL_20240212_223045812.thumb.jpg.452a6f9e22e56a33f284e15f5058e652.jpg
