4090 power
Go to solution Solved by Mando772004,
5 hours ago, Bagzie said:
If your gpu is only reaching 330w in furmark at +20% power then that's an issue with your card.
i fixed it, i was running the "gpu stress test" option not the presets that are on the application itself. i ran the presets and it reached as high as 500watts. i noticed when running the custom preset with it set to 1440p, the actual render resolution is way lower i dont know why but this was why the gpu power was very low.
i have a question, why does i see some people reaching 500w with a 4090 and i never reach that with the same model, they dont even mention that they installed a bios or anything. i just find it weird cuz even when i bumped the power limit on the strix 4090 oc to 120% it  reached 330w during a furmark test and others seem to reach as high as 495!
https://linustechtips.com/topic/1557641-4090-power/
CPU : Ryzen 7 7800X3D @ -30mv All core
CPU Cooler : Thermalright Frozen Prism 240mm AIO
Mobo : Asrock B650m Pro RS Wifi
Ram : 32GB (2X16GB) Lexar Ares 6000MHZ CL 28-36-36-68
GPU : MSI Gaming X Slim 4070Ti Super 16GB ( 308W PL +140 Core +1000 Memory )
Storage : 2TB Verbatim Vi5000 Gen 4 NVME
PSU : Thermalright TG-750w 80+ Gold ATX 3.0 PCIE 5.0
Case : Fractal Design Pop Mini MATX
Case Fans : 3 X Thermalright TL-C12C-S RGB
Monitor :27" Samsung Odyssey G5 2560 x 1440 180 HZ IPS
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
https://linustechtips.com/topic/1557641-4090-power/#findComment-16317538
Well sorry no it reached 330w with 100% power limit i noticed that after, however in other benchmarks it can reach up to 430w like 3dmark for example
https://linustechtips.com/topic/1557641-4090-power/#findComment-16317646
And all games run at very normal power usage its just furmark thats a bit too low, for other benchmarks it can hit 400w+ but never  495 like other people. Im certain my hardware is fine as i had a suprim before that it also didnt reach such power. Im using the 12vphwr connector direct from my psu which is a 1200w hydroptm
https://linustechtips.com/topic/1557641-4090-power/#findComment-16317648
https://linustechtips.com/topic/1557641-4090-power/#findComment-16317913
