38 minutes ago, Buttr said:
My front panel USB c dp
oes not work and I don’t know why my case is nzxt h6 flow and my motherboard is gigabyte aero b650 g
First step, make sure the USB-C cable from the front of the case is plugged into the USB-C header on the motherboard.
Double-check to ensure it's not loose, etc.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1557487-front-panel-usb-c/#findComment-16316249
