How does disk usage really work?
Solved by Eigenvektor,
https://learn.microsoft.com/en-us/previous-versions/windows/desktop/xperf/disk-utilization
QuoteThe Usage Percentage is computed by calculating the amount of time a disk is servicing I/O requests vs. the time spent idling.
An installer will likely copy a ton of small files, which would result in a lot of individual requests. While copying a large file is likely far fewer requests followed by a straightforward moving of data.
