Build Upgrade advice
7 minutes ago, YariYGM said:Hey guys, I was looking for some advice into my build, I'm currently running a Ryzen 7 3800x custom water loop rig with a 1650 GPU, 600W PSU, 2x8GB 3200Mz Ram all on my MSI x570 A-Pro MB. I was looking to upgrade my GPU to a 4060 or 3060/Ti and ram to 32gb 3200MZ. I will be honest i am nervous about bottlenecking my CPU and not having enough power with my PSU, but I did not build my pc myself it was from Digital Storm. I don't even wanna begin to mess with my PSU cables, everything was zip tied and was not fun . I recently changed one of my fans and the pc didn't turn on because i had my connectors for power in the wrong orientation on my MB LOL. Either way she runs good now but I'd like to run my games smoother, any thoughts?
You can easily run your system with a 600w PSU if you plan on getting the 4060
It will be an easy swap as well.
The 3800x will not be a major bottleneck, nothing I would be worried about.
Buy the 4060 or AMD equivalent and continue gaming
