CPU Fan error
Go to solution Solved by Average Nerd,
2 minutes ago, Doggy_Dieter said:
At my AIO the NZXT Kraken Elite 360, there was a Fan splitter to three and I don't need to Plug this in anywhere else
Okay, so, according to the manual, you need to go into the bios and disable the CPU fan error:
Does your mobo have a dedicated pump header?
If it does, check the BIOS if you can set it to use that instead of expecting something from the CPU header.
English is not my first language, so please excuse any confusion or misunderstandings on my end, also I like to edit my posts a lot.
F@H-Stats
The Rigs:
Xenon:
CPU: 2x Xeon E5 2690 V3
RAM: 64GB DDR4 2133 RDIMM
MoBo: Supermicro X10DRi-T4+
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
RAM: 48GB DDR4 3200 UDIMM
MoBo: ASRock B550M Pro4
The Laptop (Lenovo Legion 5 15IAH7):
CPU: Core i5 12500H
RAM: 16GB (2x8GB) DDR5-4800
GPU: RTX 3050 Ti mobile
OS: Windows 11 Home
The Tablet:
Dell Latitude 7212 Rugged Extreme Tablet (Core i5 8350U/8GB RAM)
OS: Windows 11 Pro
https://linustechtips.com/topic/1555773-cpu-fan-error/#findComment-16304889
1 minute ago, Doggy_Dieter said:
My mobo has a Pump Header. The mobo is a ROG Strich x670ea
Are the AIO fans plugged into the CPU fan header or a case fan header? They should be on the CPU fan header.
F@H-Stats
The Rigs:
Xenon:
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
CPU: Core i5 12500H
OS: Windows 11 Home
The Tablet:
OS: Windows 11 Pro
https://linustechtips.com/topic/1555773-cpu-fan-error/#findComment-16304906
At my AIO the NZXT Kraken Elite 360, there was a Fan splitter to three and I don't need to Plug this in anywhere else. They aren't plugged AS Chassis Fans or CPU Fans but I could Plug one into the CPU Fan header
Edited by Doggy_Dieter
https://linustechtips.com/topic/1555773-cpu-fan-error/#findComment-16304916
F@H-Stats
The Rigs:
Xenon:
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
CPU: Core i5 12500H
OS: Windows 11 Home
The Tablet:
OS: Windows 11 Pro
https://linustechtips.com/topic/1555773-cpu-fan-error/#findComment-16304917
Just now, Doggy_Dieter said:
But how so I do THAT? On Asus Uei
Press F1 and locate the "CPU Fan Speed Power Limit" setting and set it to ignore. (Basically what the error screen says).
F@H-Stats
The Rigs:
Xenon:
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
CPU: Core i5 12500H
OS: Windows 11 Home
The Tablet:
OS: Windows 11 Pro
https://linustechtips.com/topic/1555773-cpu-fan-error/#findComment-16304927
