Hi guys i just ordered my first pc and i need help with the case fans i got a logic aramis argb case cuz it had 3 fans included but i dont know how to plug them i added photos of the cables that come out of the fans the front fans have these two small cables and the back fan has the big one and the one with four pins please help!!
https://linustechtips.com/topic/1555547-case-fans/
That is an RGB Connector and will go into you're mainboard.
The second one is actually really really weird, it has a S-ATA Connector and an Female 4 Pin????
Anyway, the big connector is the same as on 2.5" ssd's/modern HDD's (just Sa SATA (also called S-ATA) connector wich delivers power).
R7 7800X3D | RTX 4090 | 32GB 5200Mhz RAM | BeQuiet Dark Power 13 1000W | ASRock X670E Taichi | WD Blue SN570 2 TB | Samsung 960 Pro 1TB | FireCuda 2TB | 120 TB NAS |
Don't forget to mark the solution!
https://linustechtips.com/topic/1555547-case-fans/#findComment-16303383
I actually found out that the only thing that matters is the sata power and i dont really care about rgb and the female connector was to connect all the fans to the one sata cable thanks tho
https://linustechtips.com/topic/1555547-case-fans/#findComment-16303398
First photo: top connector is standard ARGB and you should find one on the outskirts of your mobo (most brands). The other one connected to it is the alternative for certain other brands - I don't recall which.
2nd: to is male PWM connector for fan control. Bottom is SATA power cable to PSU cable.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1555547-case-fans/#findComment-16305152
