New PC build, Same Old Problem
Go to solution Solved by Agall,
12 minutes ago, RosieDreams said:
Built a new PC as my old one was having a ton of issues likely being the motherboard either due to it's age or a bad PSU I had to RMA. I just built this new PC and everything runs amazing except for the Bluetooth Dongle brought from my old PC. When plugged in the audio in connected earbuds crackles and distorts (even worse if a controller is simultaneously connected) and it even makes my PC occasionally lag/stutter with the mouse lagging and a weird rapid beeping noise. These same issues happened in my old build, so it has to be the adapter, right? Is it possible that connecting this likely faulty dongle damaged my new PC? Is there a better Bluetooth solution for multidevice connection?
New PC Specs:
Motherboard: ASUS Prime Z-690-A
RAM: 32gb DDR5 6000MHz
CPU: i5-12600K
PSU: EVGA 750 GQ, 80+ GOLD
OS: Windows 10 Pro
GPU: Zotac 3060 ti lhr
Sounds like the dongle is just faulty, I would suggest getting a PCIe WLAN/bluetooth adapter that you can put in the bottom most slot. The most economical thing is to get it built into the motherboard, but you're already past that point since it doesn't appear that your motherboard has it built in.
Amazon.com: TP-Link WiFi 6 PCIe WiFi Card for Desktop PC AX3000 (Archer TX55E), Bluetooth 5.2, WPA3, 802.11ax Dual Band Wireless Adapter with MU-MIMO, Ultra-Low Latency, Supports Windows 11, 10 (64bit) Only : Electronics
Something like this.
New PC Specs:
CPU: i5-12600K
OS: Windows 10 Pro
https://linustechtips.com/topic/1555377-new-pc-build-same-old-problem/
New PC Specs:
CPU: i5-12600K
OS: Windows 10 Pro
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
Try updating drivers. First thing I would try is plugging Bluetooth Dongle into different USB port. Making sure there is nothing physically blocking signal between dongle and bluetooth device.
And obviously if you have a ton of bluetooth devices there is gonna be interference.
Yeah, I was initially going for one with it built in, but this one had everything else I needed and more otherwise and I found it at a really good price at Microcenter (also helps that it aesthetically fits my case perfectly.) I foolishly thought the dongle would be okay, but I'll definitely check that PCIe option out. No chance I actually hurt anything plugging in that dongle then?
I did give that a go with no better results sadly. Tried the usb at the back of my MoBo and the one at the front on the case. Same issue. I also found that Windows couldn't find the newest driver for it so I manually downloaded and installed it from the manufacture's website and still same issues (actually a little worse as the new driver desynced the voulme of my earbuds with the volume of the PC.) As far as devices I only ever have my Earbuds and 8BitDo connected.
