Hi!
Today I’ve been trying to fix this old record player, and I was able to get it spinning, but I’m having trouble connecting it to a speaker. It didn’t have a needle, so I put in a cut in half sewing needle, so maybe it’s the wrong size and not working? Anyone know how to connect the speaker? I’m struggling to find where the ground goes.
https://linustechtips.com/topic/1555009-help-wiring-record-player/
How many pins are there on the back of the cartridge, two, three, or four?
Do you have a phono preamp to use with it, or a receiver with a phono input? Those things don't put out line level, and there's an equalization curve that has to be applied to correct the sound.
