Budget (including currency): 1000-1500 (can go above if necessary)
Country: England, UK
Games, programs or workloads that it will be used for: I've been gaming on on PC for about 5 years now and my last two pc's have both been pre-builts. I have since landed myself a Tech job which is also a main reason for why im wanting an upgrade (plus the fact its been about 3 years since ive had my current).
I play mostly single player games however i do also play games other big multiplayer games however i have never been able to experiance smooth high end gameplay which i would love, i do intend to want to play lost of newer games (as long as there good) which i belive is requiring more and more.
Due to my job i WFH most of the time so my PC is a major work requirement and i will need to multi-task as they say so having multiple software open, chrome tabs etc so ive been looking at/considering i7 13/14700(k/kf) or a good AMD alternative.
FYI : As this will be my first time building a PC from scratch i ahve been looking on PCPartPicker at such but not been able to find good builds to match or when selecting myself i constantly feel like i may be missing out choossing some parts over other, so any help/build ideas would be much appreciated.
https://linustechtips.com/topic/1554266-first-gamingwork-pc-build/
Does anything in your work need an nvidia card?
Do you have/will you retain a spare graphics card?
PCPartPicker Part List: https://uk.pcpartpicker.com/list/Dx69Fs
CPU: Intel Core i7-14700F 2.1 GHz 20-Core Processor  (£359.99 @ Amazon UK)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  (£39.00 @ Computer Orbit)
Motherboard: MSI B760M GAMING PLUS WIFI Micro ATX LGA1700 Motherboard  (£151.18 @ Ebuyer)
Memory: Corsair Vengeance 64 GB (2 x 32 GB) DDR5-5600 CL40 Memory  (£158.99 @ Ebuyer)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£108.99 @ AWD-IT)
Video Card: Sapphire PULSE Radeon RX 7800 XT 16 GB Video Card  (£509.99 @ Ebuyer)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case  (£89.00 @ Computer Orbit)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£113.70 @ Amazon UK)
Total: £1530.84
Generated by PCPartPicker 2024-01-23 14:26 GMT+0000
what resolution do you plan to game at
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
Does your job pay for the computer or any portion of it? Are there any requirements for home use of PC used for work also? I am thinking you may want to get two SSD and have two separate windows installations if so.
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
29 minutes ago, voyager_ said:
I think we are going to need more detail about the software and games that you are trying to run.
Sorry about that
for games such as : Cyberpunk, Warzone, CSGO, RDR2, GTA V (ideally 6 too if it comes to PC) & New World
For work main reason im thinking to have good CPU & RAM : i use a work VPN to access a lot of backoffice applications and in-house software. More namely software would be things like VS Code, mRemoteNG also Adobe products like PS, Illustrator (little bit for personal use).
Hope that helps
Unfortunatly my job does not pay for the computer or any part of it, we are given a laptop to use when at home but its not ideal as i cannot have open as much stuff as i would ideally like to at once without it slowing down on preformance.
I've not came across any issues yet that may idicate i would need too?
I'm also aware of other people whom i work with that do the same as me for some things like chrome for example its easy enough to have a seperate profile etc.
Definetly something i can look into if it would benefit me more?
Thanks
At the moment i have 2 monitors both 1080p
Planning to upgrade sometime after i have a new PC potentially look into a higher resolution screen but not in dire need at the moment (Can upgrade pc down the line if needed)
FYI : As this will be my first time building a PC from scratch i ahve been looking on PCPartPicker at such but not been able to find good builds to match or when selecting myself i constantly feel like i may be missing out choossing some parts over other, so any help would be much appreciated.
I'd go for this for AMD
CPU: AMD Ryzen 9 7900 3.6 GHz 12-Core Processor  (£377.00 @ Amazon UK)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  (£159.97 @ Amazon UK)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-5600 CL28 Memory  (£110.58 @ Amazon UK)
Storage: Intel 670p 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (£89.99 @ Scan.co.uk)
Video Card: Palit Dual GeForce RTX 4070 SUPER 12 GB Video Card  (£579.00 @ Computer Orbit)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  (£54.98 @ Scan.co.uk)
Power Supply: *Cooler Master MWE Gold 850 - V2 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£99.99 @ AWD-IT)
Total: £1510.51
Generated by PCPartPicker 2024-01-23 15:25 GMT+0000
And this for intel
CPU: Intel Core i7-14700K 3.4 GHz 20-Core Processor  (£383.00 @ Amazon UK)
Motherboard: MSI PRO Z790-A WIFI DDR4 ATX LGA1700 Motherboard  (£179.90 @ Amazon UK)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  (£80.98 @ Ebuyer)
Total: £1506.84
Generated by PCPartPicker 2024-01-23 15:27 GMT+0000
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
Does your company's IT policy allow personal computers. At any company i've worked for that is a huge security concern and no allowed. If it's not allowed and something happens they could try to hold you responsible for any damages.
Personal computers are allowed as long as certain security processes' are followed (the work that requires VPN usage is done via work laptop) - Which have been (Plus it was confirmed with security deptartment at my company)
However, thank you for your concern.
