First PC
Go to solution Solved by jaslion,
This would have been a ok gaming pc 3 years ago. But its old? Any reason for these parts chocies as they are all old.
PCPartPicker Part List: https://au.pcpartpicker.com/list/bkvJRK
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($205.00 @ BPC Technology)
CPU Cooler: Thermalright Assassin X Refined SE ARGB 66.17 CFM CPU Cooler  ($39.00 @ Amazon Australia)
Motherboard: Asus PRIME B760M-K D4-CSM Micro ATX LGA1700 Motherboard  ($189.00 @ Computer Alliance)
Memory: TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($94.00 @ Scorptec)
Storage: Crucial P3 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($88.00 @ Centre Com)
Case: Silverstone PS15 MicroATX Mid Tower Case  ($59.00 @ Scorptec)
Power Supply: Gigabyte UD750GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($117.00 @ MSY Technology)
Total: $791.00
Generated by PCPartPicker 2024-01-23 18:48 AEDT+1100
Id say start wih this and go to your local cex or whatever to get a certifird used/refurb card like a rx6700xt as that is in the 400aud budget
I madr these changes mainly so you have better cooling and airflow as the cooler you took was old and not good and the case has NO airflow.
Budget: $1,000 - $1,200 AUD
Country: Australia
Games, programs or workloads that it will be used for: mostly games, school and mabye even streaming
Parts list:
PCPartPicker Part List: https://au.pcpartpicker.com/list/393M6D
CPU Cooler: ARCTIC Freezer 7 X CPU Cooler  ($29.00 @ PCCaseGear)
Motherboard: Gigabyte B660-AORUS-ELITE-DDR4 ATX LGA1700 Motherboard  ($239.00 @ PCCaseGear)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($99.00 @ Amazon Australia)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($169.00 @ Computer Alliance)
Video Card: Gigabyte GAMING OC GeForce RTX 2060 SUPER 8 GB Video Card
Case: Azza Spectra ATX Mid Tower Case
Power Supply: Thermaltake Toughpower GX1 600 W 80+ Gold Certified ATX Power Supply  ($89.00 @ Centre Com)
Case Fan: ARCTIC P12 PST 56.3 CFM 120 mm Fans 5-Pack  ($45.00 @ Mwave Australia)
Total: $875.00
Reply to this thread if you hav ideas on what to replace or remove
https://linustechtips.com/topic/1554224-first-pc/
Total: $791.00
https://linustechtips.com/topic/1554224-first-pc/#findComment-16294127
5 hours ago, Ders_09 said:
Thank you jaslion because I had no clue what I was doing and this was very helpfull, the only bad thing I have to say about this I don't think this is as upgradable as my version and the 750 WATTS! but I will be using your build.
How do you mean upgradeable?
Also whats the issue with the 750w psu?
A power supply only delivers as much as its asked. So if a pc asks like 300w the psu will consume a bit more than 300w of power to deliver it to the system (ac/dc conversion is never lossless). The 750w on the unit means a UP TO 750w. Not will always consume 750w of power.
So it is actually more upgradeable in that regard.
As for gpu defo have a look at thr cex or whatever its called refurb section. They have lots of good priced cards. Id say first have a look there, reach back to us here (just ping or quote us in this thread) with a list of options and we can then budget adjust the build more if needed as that is still possible
https://linustechtips.com/topic/1554224-first-pc/#findComment-16294391
