Havent found a solution or cause for this and decided to create a new account to ask.
I tried to use the Samsung G9 G95SC, Samsung C27RG50FQL both at 240hz and a Wacom Cintq DTK1660K0A.
The issue is that both monitors won't run at 240hz unless the third monitor is disconnected.
If the Wacom monitor is connected, the refresh rate of one of the monitors is changed to 120hz, if changed to 240hz there is no display output in the afected monitor.
my current workaround is connecting an intel arc A380 and conecting one of the monitors, but this also causes issues as the RTX 3080 fans run at full speed.
Specs:
  • OS - Windows 11
  • Ryzen 7 5800x
  • PNY Uprising Epic-X RTX 3080ti
  • Gigabyte X570 AORUS Master
  • Seasonic Prime Ultra 1000W
https://linustechtips.com/topic/1553703-multi-display-setup-having-issues/
my current workaround is connecting an intel arc A380 and conecting one of the monitors, but this also causes issues as the RTX 3080 fans runs at full speed.
Specs:
  • OS - Windows 11
  • Ryzen 7 5800x
Latest graphic drivers?
