Recently my display started shutting off randomly, and stay off until I turned it off and back on and it would work again. This got more frequent to the point I no longer got a display, my GPU fans still turned so I just decided to replace my graphics card. Just today I put in a new card and.. Nothing.
SPECS:
AMD Ryzen 2600
Random Motherboard
GTX 1660 Super (replaced with AMD 7970)
Random PSU
https://linustechtips.com/topic/1553650-no-display-output/
Just now, Brodyismyname said:
Gamdias Kratos M1 550b
Also I tried switching out RAM and still nothing. The Computer can’t be turned off by power switch on the case, I have to flip the switch on the PSU
Everything gets power though so I don’t see that being the reason. My last thing is probably get a new motherboard or CPU
https://linustechtips.com/topic/1553650-no-display-output/#findComment-16290392
That's a bad unit.
Did you reset the motherboard BIOS?
https://linustechtips.com/topic/1553650-no-display-output/#findComment-16290564
5 hours ago, --SID-- said:
That's a bad unit.
I’m gonna YouTube it and find out if it works, I’ll update you once I know. And I agree with you, the PSU looks sketchy, and if I have to replace the motherboard  im going to get a modular psu
https://linustechtips.com/topic/1553650-no-display-output/#findComment-16290820
6 hours ago, --SID-- said:
That's a bad unit.
Update: It’s a BIOSTAR A320mh motherboard, I moved the Jumper Cables and took out the battery(for 10 minutes) the system still powers up but no display, and I still have to turn it off via power supply
https://linustechtips.com/topic/1553650-no-display-output/#findComment-16290876
  • 4 weeks later...
Update: I fixed it, just needed to replace motherboard
https://linustechtips.com/topic/1553650-no-display-output/#findComment-16320440
