Having Problem with my new build
Solved by Robchil,
1 minute ago, Rando_User1234 said:I checked that list as well, and didn't find this exact model. The closest one was CMH32GX5M2E6000C36. But I thought that the list was just for orientation, to say which speeds work and stuff. This RAM is AMD EXPO ready, and I thought it was good. Was it a bad move to not take a memory stick that is actually listed in that list?
i guess it would be easier to get some form of support from the vendor..
