Best 55inch-65inch tv for £700
Solved by EwanJ,
14 hours ago, IR76 said:4k Ultra HDR. 3,840 x 2,160 and suggest any company you want but preferably either LG or Samsung as I know Samsung tvs last ages based on the other ones i have.
Yeah, sorry for the late ass reply I literally just past out haha specially with the snow i had to grit out all my parents driveway. Yeah I found one for under with the rated specs you were looking for, you could invest to an actual sound bar aswell with it
