Budget (including currency): 500 USD
Country: US
Games, programs or workloads that it will be used for: It will be for gaming (Valorant, Hades, CODMW2, Dota 2, and bg3) and for excel
I already have a build that I built last year but I did get a job that will require me to move or travel every 3 months. I did saw a thread that is almost similar to this but my case is different I will be just traveling with my car. This is the build that I have https://pcpartpicker.com/list/kvrVCd so I am thinking of putting the parts to a smaller case or make it an ITX build so that I be also save space and easier to bring with me. I am for sure that I can't use all of the parts like the MOBO and the PSU if you can help me with the parts especially which parts that I can reuse that would be helpful. I do also have a portable monitor and a 1440p 240hz monitor. Thx for the help.
Sorry for bad English not my native language
https://linustechtips.com/topic/1553338-help-with-pc-for-traveling/
Country: US
The sama IM01 is a great case and it’s an Matx one that can fit your atx psu, and I’m quite sure it can fit your aero 4070 https://pcpartpicker.com/product/pfvdnQ/sama-im01-microatx-mini-tower-case-im01
I’d get that case with this mobo (there’s only one matx z790 and it wasn’t great) https://pcpartpicker.com/product/mB2WGX/msi-mpg-z790i-edge-wifi-mini-itx-lga1700-motherboard-mpg-z790i-edge-wifi
you can get a b760 matx tho (but on the description of the sama im01 you’ll get more space in the case https://pcpartpicker.com/product/ysvD4D/msi-mag-b760m-mortar-wifi-ii-micro-atx-lga1700-motherboard-mag-b760m-mortar-wifi-ii
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
Thx! Will I be able to use the cooler with this case? I saw a lot of people use low profile or aio for ITX builds.
This case supports up to 335mm length gpus and the aero 4070 is only 300 so yes, it’ll be fine. You can use an aio but it’ll have to be a thinner one and you’ll have to get an itx board. The thermalright pa120 should fit, if the cooler doesn’t then you can get a lower one after the fact
Total: £1040.95
I have a Noctua NH-U12 in that case, which is a tight fit, but it works. You just have to remove the side bracket that is meant for extra fans/rad/storage.
And please get an itx motherboard in this case. The IM1 supports mATX, but it might prevent you from installing fans in the bottom or plugging some stuff into the bottom of your board. For me, it was the audio connector that wouldn't fit with fans in the bottom.
I do recommend the Sama/Intertek IM1 though. It is quite cheap, easy to build in and sturdy on the outside.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
Yes I am planning to switch to an ITX motherboard. I will look at that case and see if I will like it. Thx!
