So:
I Had A PSU Off My Friend Which Is A: Chicony 500w Modular PSU,
It Only Has CPU And PCI-E Connectors, No Sata, No Molex And No 24 Pin Either, He Said I Come With His Prebuilt Predator Gaming PC But I Don’t Understand How I Can Connect This And Everything Works?
As You Can See There’s No Additonal Ports Or Wires,
Can I Still Set This Up In My PC?
Help Me Please? 😂
https://linustechtips.com/topic/1553105-psu-help/
Then it's not going to be of much use.
What I think is going on is that this PSU is one of those 12V only PSUs, that offload the other voltages to regulators in a separate module or on the motherboard.
English is not my first language, so please excuse any confusion or misunderstandings on my end, also I like to edit my posts a lot.
F@H-Stats
The Rigs:
Xenon:
CPU: 2x Xeon E5 2690 V3
RAM: 64GB DDR4 2133 RDIMM
MoBo: Supermicro X10DRi-T4+
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
RAM: 48GB DDR4 3200 UDIMM
MoBo: ASRock B550M Pro4
The Laptop (Lenovo Legion 5 15IAH7):
CPU: Core i5 12500H
RAM: 16GB (2x8GB) DDR5-4800
GPU: RTX 3050 Ti mobile
OS: Windows 11 Home
The Tablet:
Dell Latitude 7212 Rugged Extreme Tablet (Core i5 8350U/8GB RAM)
OS: Windows 11 Pro
https://linustechtips.com/topic/1553105-psu-help/#findComment-16285777
Take a picture of the label, if there is one. As @Average Nerdsaid, this power supply probably supplies standard 12 volts to the motherboard
If your PC only needs a CPU and graphics card power connector, yes you can. Sounds like you will have no issue if you use an m.2 SSD
But check out this adapter
https://a.co/d/88LJSg7
Convers the 5v that comes off the USB to give you SATA power if you need it.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1553105-psu-help/#findComment-16285780
And if you have a motherboard that doesn't need a ATX 24 pin connector.
F@H-Stats
The Rigs:
Xenon:
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
CPU: Core i5 12500H
OS: Windows 11 Home
The Tablet:
OS: Windows 11 Pro
https://linustechtips.com/topic/1553105-psu-help/#findComment-16285783
Whoops I did overlook that. I forgot that 12vo has that separate transformer on the mobo for 5v
Primary PC:
PSU tier list
https://linustechtips.com/topic/1553105-psu-help/#findComment-16285787
Looks like ewaste, it can only be used in OEM non standard boards, get a standard one if you're building a PC
https://linustechtips.com/topic/1553105-psu-help/#findComment-16285800
Yeah I’ve Got A A320M-K So 100% I Need A 24Pin
What budget do you have ?
https://linustechtips.com/topic/1553105-psu-help/#findComment-16285877
Then your only option is to buy a standard ATX PSU.
F@H-Stats
The Rigs:
Xenon:
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
CPU: Core i5 12500H
OS: Windows 11 Home
The Tablet:
OS: Windows 11 Pro
https://linustechtips.com/topic/1553105-psu-help/#findComment-16285878
