Hey guys i seem to be getting a crackling noise when ever i open a new tab in my headset. I currently have a Astro TX wireless mix amp plugged in via Optial and it connected to the RX mix amp via a usb/what ever it uses to transmit all this is plugged into a Asus Xonar DX. what would be the cause? if you need anymore info just tell me what you need. :)
Cpu: 5820K @4.0GHz   Motherboard: Gigabyte X99-SLI    Ram: Patriot Signature 16GB @ 2133   GPU: Gigabyte G1 980  Soundcard: ASUS DX
 Speakers: Logitech Z906 and Astro A40's   Keyboard: Logitech G510
https://linustechtips.com/topic/15526-crackling-noise/
You mean opening a web browser tab?
I think i've had something similar, where if i plug a 3.5mm headphone jack into my front panel and then put a usb device in next to it i could head a static that sounded like the data rate :s
Have you tried plugging other headphones into the amp to see if you hear the same noise?
If the nose doesn't seem so show then there's probably some interference with the wireless signal.
You can probably fix that by turning off wireless transmission from other devices around you.
Another plausible explanation is that there's interference from your motherboard, and it is being transferred through the digital interface (USB) as a static sound.
I'm not really sure how to fix something like that... but yer sorry i can't be of more assistance =[
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
https://linustechtips.com/topic/15526-crackling-noise/#findComment-174005
web tab or a folder. Thats cool thanks for the suggestions :)
https://linustechtips.com/topic/15526-crackling-noise/#findComment-174016
Try mutting the MIC, something similar happend to me a few weeks ago and that was the solution.
Mobo: Asus Maximus Impact VI Processor: Intel 4690K @ 4.4Ghz 1.22Vlts Memory: 2x8 GB DDR3 1866Mhz GSkill Sniper
VGA: Sapphire HD 7970 3GB OC Audio: Asus Impact Supreme FX SSD: Mushkin Chronos 120GB HDD: WD Black 500GB
Power Supply: Coolermaster V650 Semi Modular Case: Bitfenix Prodigy Cooling: Corsair H100i
https://linustechtips.com/topic/15526-crackling-noise/#findComment-174368
