Please keep related posts in previous threads instead of making new ones for the same issue
However, this could be just normal running or possibly capacitor squeal, which can be not good, if its a new PSU id recommend RMAing
Just seen you have a problem RMAing, has your warranty ran out? I dont see how it would have as PSUs generally have a minimum of 5 year warranty and the RMe series released in 2023
Or is there something else?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1550859-psu-noise/#findComment-16270251
34 minutes ago, shod1213 said:
Hi,
So this is the noise my psu (RM850e)
does when my pc is running even on idle. What does it mean? Is this dangerous to the components?
I wouldn't worry about it, but yes you could RMA and most likely get a new PSU. Seem a little much if this is in idle, but hard to tell how loud it is from the recording.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1550859-psu-noise/#findComment-16270252
