Im having issues with my new ryzen 7 5800x3d, it is running extremely hot, i already replaced my cooler because i thought it was broken but it didnt solve it, after replacing the cooler i thought of undervolting him but while following a guide i noticed that im missing some options on the bios (Aorus B450 Elite) voltage section.
Im supposed to have these options but i only have the last one
https://linustechtips.com/topic/1549649-undervolting-issues/
What is the temperatuers you are seeing and what cooler did you get?
https://linustechtips.com/topic/1549649-undervolting-issues/#findComment-16262789
Same bios. Which article is it? A link?
https://linustechtips.com/topic/1549649-undervolting-issues/#findComment-16262798
1 hour ago, DeLuN said:
What's the temperature at idle, max, and gaming/doing some task. How hot is extremely hot? When it is hot, what's the frequency? If the CPU is not lowering the clock speed, then it is probably fine.
its reaching 90 celsius while gaming and the frequency lowers to around 3Mhz.
https://linustechtips.com/topic/1549649-undervolting-issues/#findComment-16262886
You did take the plastic sticker off the bottom of the cold plate on the cooler right and it has got thermal paste on it?
If so you might have a duff pump but it's hard to say based off what you have told us.
CPU : Ryzen 7 7800X3D @ -30mv All core
CPU Cooler : Thermalright Frozen Prism 240mm AIO
Mobo : Asrock B650m Pro RS Wifi
Ram : 32GB (2X16GB) Lexar Ares 6000MHZ CL 28-36-36-68
GPU : MSI Gaming X Slim 4070Ti Super 16GB ( 308W PL +140 Core +1000 Memory )
Storage : 2TB Verbatim Vi5000 Gen 4 NVME
PSU : Thermalright TG-750w 80+ Gold ATX 3.0 PCIE 5.0
Case : Fractal Design Pop Mini MATX
Case Fans : 3 X Thermalright TL-C12C-S RGB
Monitor :27" Samsung Odyssey G5 2560 x 1440 180 HZ IPS
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
https://linustechtips.com/topic/1549649-undervolting-issues/#findComment-16263013
yeah seems like i forgot to take out the plastic xD
Thanks for mentioning that, seems like it solved it ❤️
https://linustechtips.com/topic/1549649-undervolting-issues/#findComment-16263045
