Seeking Advice: Gigabyte Z790 AORUS ELITE AX ICE for Intel i7 14700K Compatibility?
Solved by rippy4500,
Its an ok board, I have the Z790 aorus elite ax which is very similar. And im using a 14900kf without any major problems so the 14700k should work just fine assuming you have the right bios. Ive had a few technical issues with this board in general though like not starting up every now and then (which happened on my old 13700k as well) so id recommend a different board probably.
I heard the asrock z790 nova is a pretty good choice, its supposed to be able to oc memory better than most boards as well. It costs a little more than the gigabyte one but should be a better board overall.
