Need Advice
Go to solution Solved by PDifolco,
2 minutes ago, Sjaakie said:
Your pcpartpicker list is private.
Yeah
And anyway don 't buy a $300 RTX3060...You can get a way better 6700XT at that price
Budget (including currency):  $200 - $300
Country: USA
Games, programs or workloads that it will be used for: Ark, Warzone, Fifa, RL, and Photoshop
Here Is my pc list: https://pcpartpicker.com/list/ZwJ7MV
I want to get a new gpu, I'm looking at this one: https://www.bestbuy.com/site/msi-nvidia-geforce-rtx-3060-ventus-3x-12g-oc-12gb-gddr6-pci-express-4-0-graphics-card-black/6452940.p?skuId=6452940&extStoreId=1419&utm_source=feed&ref=212&loc=19898054555&gad_source=1&gclid=Cj0KCQiA4Y-sBhC6ARIsAGXF1g6j9oB0gZHQetnDf9a87Hsoe1BkXtcYFlAi1SblAtBObJyDcu-JEEwaAr4SEALw_wcB&gclsrc=aw.ds
I'm still learning what goes with what but I believe this would work In my PC and Just wanted to get some advice If this Is a good choice.
https://linustechtips.com/topic/1548387-need-advice/
Yeah
https://linustechtips.com/topic/1548387-need-advice/#findComment-16254660
16 minutes ago, PDifolco said:
Yeah
Having a 27.0" Monitor I feel like I always have to change my resolution to 1980 x 1080 which makes playing games a little less enjoyable because even doing that I'm still running 60-90 frames on the big games like MW3 and FIFA. Thats partially  why I'm trying to get advice on what gpu to get I want to be able to play games without it looking like minecraft In cod.
https://linustechtips.com/topic/1548387-need-advice/#findComment-16254675
2 minutes ago, Blakaa said:
Lol okay now I fixed It.
oh you did
current PC:
PC configs I used before:
https://linustechtips.com/topic/1548387-need-advice/#findComment-16254681
What I said
3060 is 35% faster than a 1660TI, meh
6700XT is 80% faster, yeah 🙂
https://www.techpowerup.com/gpu-specs/geforce-gtx-1660-ti.c3364
https://linustechtips.com/topic/1548387-need-advice/#findComment-16254688
Is this It, https://www.newegg.com/asrock-radeon-rx-6700-xt-rx6700xt-cld-12g/p/N82E16814930056 ?
https://linustechtips.com/topic/1548387-need-advice/#findComment-16254707
